frozenthrone
第2楼2016/08/25
希望以下能帮到LZ
ASTM D1002 - 10
Standard Test Method for Apparent Shear Strength of Single-Lap-Joint Adhesively Bonded Metal Specimens by Tension Loading (Metal-to-Metal)
http://www.doc88.com/p-4953403601819.html
ASTM D1062 - 08(2015)
Standard Test Method for Cleavage Strength of Metal-to-Metal Adhesive Bonds
http://www.doc88.com/p-8899731690240.html
ASTM D1896 / D1896M - 10
Standard Practice for Transfer Molding Test Specimens of Thermosetting Compounds
网上流传最新为99版
http://www.doc88.com/p-8945287324526.html
ASTM D2182-72(1978) 金属对金属粘接压缩剪切强度的标准试验方法(圆盘剪切)
ASTM D2182-78
估计已废止
ASTM D3013 - 13
Standard Specification for Epoxy Molding Compounds
http://bbs.angui.org/thread-151056-1-1.html
ASTM D3123 - 09
Standard Test Method for Spiral Flow of Low-Pressure Thermosetting Molding Compounds
http://www.doc88.com/p-0008916821063.html
ASTM D3164 - 03(2011)
Standard Test Method for Strength Properties of Adhesively Bonded Plastic Lap-Shear Sandwich Joints in Shear by Tension Loading
网上流传最新版为03版
http://www.gfjl.org/thread-123028-1-1.html
http://bbs.myboyan.com/america/b160236/
ASTM D5224 - 12
Standard Practice for Compression Molding Test Specimens of Thermosetting Molding Compounds
http://www.doc88.com/p-1197698830935.html
ASTM D5948 - 05(2012)
Standard Specification for Molding Compounds, Thermosetting
http://bbs.angui.org/thread-145068-1-1.html
ASTM D897 - 08(2016)
Standard Test Method for Tensile Properties of Adhesive Bonds
网上流传最新版为08版
http://www.doc88.com/p-5466908582782.html
