wang2559
第1楼2006/11/06
ASTM D885-03
由人造有机纤维制成的轮胎帘子线,轮胎帘布和工业长纱线的测试
Standard Test Methods for Tire Cords, Tire Cord Fabrics, and Industrial Filament Yarns Made from Man-Made Organic-Base Fibers
ASTM D2228-02
橡胶特性试验方法.抗磨性(皮考磨损机)
Standard Test Method for Rubber Property-Relative Abrasion Resistance by the Pico Abrader Method
ASTM D2229-02
钢轮胎帘线和橡胶之间粘结性的试验方法
Standard Test Method for Adhesion Between Steel Tire Cords and Rubber
ASTM D2230-96(2002)
橡胶特性试验.未硫化橡胶化合物的可挤压性
Standard Test Method for Rubber Property-Extrudability of Unvulcanized Compounds
ASTM D2692-98
轮胎帘布织物、轮胎帘布、轮胎帘线及纱线平面透气性的测试方法
Standard Test Method for Air Wicking of Tire Fabrics, Tire Cord Fabrics, Tire Cord, and Yarns
