YB-FD-30L型真空冷冻干燥机ModelFD-30Lvacuum freeze dryer上海亿倍实业有限公司一、主要特点:(Main characteristics :)● 预冻干燥在原位进行,减少干燥过程的繁锁操作,实现了自动化;●The process of pre-freezing and drying all finishedon shelves, so it avoidsthe complicated operation and realize automation ofthe dry process.● 搁板温度误差≤1℃,干燥效果均匀;●The temperature error is less than or equalto1℃.The drying effect is uniform.● 隔板温度可调、可控、可摸索、中试和生产工艺;●The shelf temperature is adjustable and controlled.● 触摸屏操作,PID控制,显示干燥曲线;●Touching-screen operation, PID control, Display drying curve, the record device is optional.● 方形托盘不易变形,易于操作,便于清洗;●The sample tray is square so it’s easy to clean and operate.● 配置充气阀,可充干燥惰性气体;●NitrogenValve is optional.● 干燥室采用高透光无色透明有机玻璃门,在操作过程中能清晰观察物料的变化过程。 ●The drying chamber adopts transparent organic glass door,the changing process of material is clearto view.●可选配自动压塞装置,可选配共晶点测试装置。●The automatic top-press stopper device andeutecticpoint test device are optional.二、主要技术参数 Main Technical Parameter项目ItemFD-30L干燥室Dryingchamber干燥面积Freeze-dr....
