Table of Chemical Shift Ranges Type of Compound Chemical Shift Range (ppm) Relative to neat CFCl3 -F-C=O -70 to -20 -CF3- +40 to +80 -CF2- +80 to +140 -CF- +140 to +250 -ArF- +80 to +170
Chemical Shift Table
For certain compounds, the listed chemical shift pertains to the F shown in bold. The primary references for these values are: 1) the 1991 Bruker Almanac, and 2) Compilation of reported F19 NMR chemical shifts, 1951 to mid-1967 by Claude H. Dungan and John R. Van Wazer. Negative shifts are those that appear upfield of CFCl3 and positive shifts are those that appear downfield. Compound Chemical Shift (ppm) Relative to neat CFCl3 CFCl3 0.00 MeF -271.9 CF3H (in CFCl3) -78.6 CF3H (in EtO) -78.6 CF2H2 -143.6 EtF -213 FCH=CH2 -114 F2C=CH2 -81.3 F2C=CF2 -135 CF3COOH (in CFCl3) -76.55 CF3COOH (neat) -78.5 CF3COOH (in CCl4 -76.3 CF3COOC6H6 -73.85 CF3COOCH2C6H6 -75.02 CF3COOCH3 -74.21 CF3COOEt (neat) -78.7 CF3COO(CH2)n -74 to -75 C6F6 -164.9 C6H5F -113.5 p-FC6H4F -106.0 CFH2Ph -207 C6H5CF3 -63.72 C4F8 -135.15 C5F10 -132.9 CF3R -60 to -70 CHF2OR ~-82 (CF3)2CO -84.6 CH2CN -251 F2 +422.92 CF3Cl -28.6 ClF3 +116, -4 ClF5 +247,+412 CF2Cl2 -8 CFCl2CFCl2 -67.8 CFBr3 +7.38 CF2Br2 +7 IF4F(equatorial) +58.9 IF7 +170 AsF3 -40.6 AsF5 -66 [AsF6]-1 -69.5 BF3 -131.3 (CH3)2O.BF3 -158.3 (C2H5)2O.BF3 -153 [BeF4]-1 -163 MoF6 -278 ReF7 +345 SF6 +57.42 SO2F -78.5 S2O5F2 +47.2 SbF5 -108 [SbF6]-1 -109 SeF6 +55 (C2H5)2SiF2 -143.0 SiF4 -163.3 [SiF6]-2 -127 TeF6 -57 WF6 +166 XeF2 +258 XeF4 +438 XeF6 +550 NF3 147 SOF2 75.68 C6H5SO2F (dilute) 65.464 C6H5SO2F (20% conc) 65.514 SF6 (dilute) 57.617 SF6 (10% conc 57.42 SO2F2 33.17 CBr3F (dilute) 7.388 CBr3F (80% conc) 7.043 CCl2F2 -6.848 CClF3 -28.1 PF3 -34.0 (CF3)3N (dilute) -55.969 (CF3)3N (30% conc) -55.969 CF3CF2CF2I -60.470 CF4 -62.3 C6H5CF3 (dilute) -63.732 C6H5CF3 (40% conc) -63.370 PF5 -71.5 CCl2F.CCl2F (dilute) -67.775 CCl2F.CCl2F (20% conc) -67.834 (CF3)3CF -74.625 CF3CO2H (dilute) -76.530 CF3CO2H (20% conc) -76.542 CF3(CF2)5CF3 -81.60 CF3(CF2)2CF3 -81.85 [CF3CF2CF2]N -85.19 POF3 -90.7 CF3CF2CF2CF2CN -107.1 CF3CF2CF2CF2CN -105.764
