sian 2006/12/20
[quote]原文由 [B]sian[/B] 发表: 我把师傅发给我的洗底片方法上传了。你看看有没用,我都是这样做的,效果很好[em01][/quote] 好像没有传上,我复制,粘贴到下面吧 Developing of TEM Films 1. Preparation of Stock solution of D19 developer: Dissolve D19 in water according to the manufacturer's instructions 2. Development of KODAK film 4429: Dilute stock solution of D19 developer in water as follows: 1 part of D19 + 2 parts of water Before use, check the temperature of D19 developer . It should be around 20 degrees centigrade. 3. Developing time: 2.5 minutes * with brief agitation every 30 seconds 4. Washing : Wash in diluted acetic acid solution ( 1:20 dilution) for 30 seconds 5. Fixing: Prepare Fixer solution according to the manufacturer's instructions. Fix in the diluted solution for 2-5 minutes 6. Wash in running water for 20 minutes 7. Dry the film (*) The film development time depends on the emulsion setting of your microscope. In our case, we use 2.5 minutes. [img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=35883]Developing of TEM films[/url]
怪味陈皮 2006/12/20
简单的说就是显影-水洗-定影-水洗-晾干,显影和定影之间的水洗是为了洗掉底片上的显影液。 试一下用Photoshop能不能救活显影过度的底片。
sian
第2楼2006/12/20
好像没有传上,我复制,粘贴到下面吧
3. Developing time:
4. Washing :
5. Fixing:
7. Dry the film
microscope. In our case, we use 2.5 minutes.Developing of TEM films
