名称 | Description | Cat.No. |
采样罐 | TO-Can (SUMMA) Canister 6 Liter w/Gauge, 1/4" Valve | 255854 |
SilcoCan Canister 6 Liter w/Gauge and Siltek Treated 1/4" Valve | 255815 | |
毛细柱 | DM-624 60mx0.25mmx1.4μm | 7722 |
标准品 | 57种臭氧前体/PAMS 混标1ppm 存储于N2 110L气体钢瓶 | SUPELCO 41976-U |
毛细柱 | DM-1 50mx0.32mmx1μm | 7186 |
DM-PLOT Alumina/Na2SO4 50mx0.32mmx5μm | 8805 | |
DM-PLOT Alumina/KCl 50mx0.32mmx5μm | 8809 | |
采样管 | ProElut DNPH-Silica 400mg 20/pk | 65913 |
ProElut DNPH-Silica 400mg, DAUL 20/pk | 65922 | |
色谱柱 | Diamonsil C18(2) 5μmx250mmx4.6mm | 99603 |
标准品 | 13种醛酮-DNPH混标100μg/mL溶于乙腈, 1mL | 47029 |
16种醛酮-DNPH混标100μg/mL溶于乙腈, 1mL | 47030 |
标准品 | 62种EPA TO-15/17 校准混标 100ppb存储于N2 110L气体钢瓶 | SUPELCO 41974-U |
62种EPA TO-15/17 校准混标1ppm 存储于N2 110L气体钢瓶 | SUPELCO 41973-U |
毛细柱 | DM-1MS 30mx0.25mmx0.25μm | 8121 |
DM-5MS 60mx0.25mmx0.25μm | 8222 | |
样品瓶、盖垫 | 2mL样品瓶透明,100/pk | 1032 |
2mL样品瓶透明带书写处和刻度,100/pk | 1033 | |
2mL样品瓶棕色带书写处和刻度,100/pk | 1034 | |
盖,蓝色,开孔,PTFE/白色硅胶,100/pk | 1035 | |
盖,蓝色,开孔,PTFE/白色硅胶(预切口),100/pk | 1036 | |
50mL钳口顶空瓶,101x31mm,透明,100/pk | 52509 | |
标准型铝盖,硅橡胶/ 聚四氟垫,已组装100/pk | 54124 | |
安全型铝盖,硅橡胶/ 聚四氟垫,已组装100/pk | 52442 | |
标准型铝盖,无垫100/pk | 52451 | |
安全型铝盖,无垫100/pk | 52452 | |
垫,硅橡胶/ 聚四氟,无盖100/pk | 59499 | |
针头式过滤器 | 13 mm 0.22 μm Nylon 100/pk | 30039 |
13 mm 0.45 μm Nylon 100/pk | 30040 | |
13 mm 0.22 μm PTFE 100/pk | 30043 | |
13 mm 0.45 μm PTFE 100/pk | 30044 | |
25 mm 0.22 μm Nylon 100/pk | 30041 | |
25 mm 0.45 μm Nylon 100/pk | 30042 | |
25 mm 0.22 μm PTFE 100/pk | 30045 | |
25 mm 0.45 μm PTFE 100/pk | 30046 | |
采样泵 | Sampling Pump SP208-100Dual II 10-100ml/min | 13861 |
Sampling Pump SP208-1000Dual II 100-1000ml/min | 13862 | |
负压采样装置 | Sampling Kit CONFIRM DELIVERY WITH MFG>25 Siltek, Complete Kit .0012 Orifice | 255833 |
Sampling Kit CONFIRM DELIVERY WITH MFG>25 Siltek, Complete Kit .0016 Orifice | 255834 | |
Sampling Kit CONFIRM DELIVERY WITH MFG>25 Non-Silcosteel, Complete Kit .0012 Orifice | 255838 | |
Sampling Kit CONFIRM DELIVERY WITH MFG>25 Non-Silcosteel, Complete Kit .0016 Orifice | 255839 |
