PDFgetX3_v2的官网介绍页面在https://www.diffpy.org/products/pdfgetx.html 但这个网页上并没有下载链接,而是需要你去 Columbia Technology Ventures注册
0. 如果你想免费安装PDFgetX3_v2, 你需要有一个"@*.edu.*"的邮箱. 如果你没有教育邮箱,就只能花钱买xPDFsuite了....其他的license都有Acadamic优惠,具体看下一步 1. PdfgetX3的whl(安装文件)只能到哥伦比亚大学的网站上注册后下载: https://columbia.resoluteinnovation.com/technologies/M11-120 要学会看英文,点上面网页上的Express Licensing, 点"Sign In To Continue" 去填好注册信息,注意用教育邮箱. 2. 重新登录你刚注册的账户后,在Express Licensing页面的Avalable Licenses里面点中 "PDFgetX3 and PDFgetN3, Free Academic", 通过下面的三个步骤填写你的个人信息学校信息等申请license, 然后静候佳音,一般几个工作日之内你就能收到哥伦比亚大学版权方给你的邮件链接 3. 通过链接下载 diffpy.pdfgetx-2.2.1-py2.py3-none-any.whl文件 4.用PDFgetX3发文章要引用: P. Juhás and T. Davis, C. L. Farrow, S. J. L. Billinge PDFgetX3: A rapid and highly automatable program for processing powder diffraction data into total scattering pair distribution functions, J. Appl. Crystallogr. 46, 560-566 (2013) 用PDFgetN3发文章要引用: P. Juhás, J. N. Louwen, L. van Eijck, E. T. C. Vogt, S. J. L. Billinge PDFgetN3: atomic pair distribution functions from neutron powder diffraction data using ad hoc corrections, J. Appl. Crystallogr. 51 (2018) 用PDFgetS3发文章要引用: CH Liu, E. Janke, R. Li, P. Juhás, O. Gang, D. V. Talapin, S. J. L. Billinge sasPDF: pair distribution function analysis of nanoparticle assemblies from small-angle-scattering data.
