意境
第2楼2007/01/12
文章是这样的,谢谢!
(1)ADOU K, BONTOYAN W R , SWEENEY P J . Multi-residue method for the determination of pesticide residues in fruits and vegetables by accelerated solvent extraction and capillary gas chromatography [J ] . J Agric Food Chem, 2001 , 49(9) : 4153 -4160.
[2]UENO E,OSHIMA H,SAITO I,et al. Multi-residue analysis of pesticides in vegetables and fruits by GC/MS after GPC and graphitized carbon column cleanup[J].J AOAC Int,2004,87(4):1003-1015.
[3]ALBERO B,SANCHEZ-BRUNETE C,TADEO J. Analysis of pesticides in honey by solid-phase extraction and gas chromatography-mass spectrometry[J].J Agric Food Chem,2004,52:5828-5835.
[4]ANASTASSIADES M,LEHOTAY S. Fast and easy multi-residue method employing acetonitrile extraction/partitioning and" dispersive solid-phase extraction" for the determination of pesticide residues in produce [ J ].J AOAC Int,2003,86 (2):412-431
