存货编码 | 存货名称 | 规格型号 | 包装 | CAS |
XW00562351 | 四氯化碳 | 99.5%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 56-23-5 |
XW00562352 | 四氯化碳 | 99.5%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 56-23-5 |
XW00641751 | 乙醇 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 64-17-5 |
XW00641752 | 乙醇 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 64-17-5 |
XW00676851 | 二甲基亚砜 | 99.7%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 67-68-5 |
XW00676852 | 二甲基亚砜 | 99.7%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 67-68-5 |
XW00676853 | 二甲基亚砜 | 99.7%, HyDry,Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 67-68-5 |
XW00713631 | 正丁醇 | 99.5%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 71-36-3 |
XW00714322 | 苯 | 99%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 71-43-2 |
XW00750581 | 乙腈 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 75-05-8 |
XW00750582 | 乙腈 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 75-05-8 |
XW00750583 | 乙腈 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 75-05-8 |
XW00750921 | 二氯甲烷(2~8℃) | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 75-09-2 |
XW00750922 | 二氯甲烷(2~8℃) | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 75-09-2 |
XW00750923 | 二氯甲烷(2~8℃) | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 75-09-2 |
XW00756501 | 叔丁醇 | 99.5%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 75-65-0 |
XW00792091 | 乙酸甲酯 | 99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 79-20-9 |
XW00964791 | 2-甲基四氢呋喃 | 99%, HyDry,with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 96-47-9 |
XW01099991 | 四氢呋喃 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 109-99-9 |
XW01099992 | 四氢呋喃 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 109-99-9 |
XW01099993 | 四氢呋喃 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 109-99-9 |
XW01271843 | 四氯乙烯 | 99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 127-18-4 |
XW01271951 | N,N-二甲基乙酰胺 | 99.8%, HyDry, Water≤50 ppm (by K.F.), HySeal (沃凯) | 100ml | 127-19-5 |
XW01271956 | N,N-二甲基乙酰胺 | 99.8%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 127-19-5 |
XW08725041 | 1-甲基-2-吡咯烷酮 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 872-50-4 |
XW08725043 | N-甲基吡咯烷酮 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 872-50-4 |
XW16340441 | 甲基叔丁基醚 | 99%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 1634-04-4 |
XW00675611 | 甲醇 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 67-56-1 |
XW00675612 | 甲醇 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 67-56-1 |
XW00675613 | 甲醇 | 99.9%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 67-56-1 |
XW00676301 | 异丙醇 | 99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 67-63-0 |
XW00681222 | N,N-二甲基甲酰胺 | 99.8%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 68-12-2 |
XW00681223 | N,N-二甲基甲酰胺 | 99.8%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 68-12-2 |
XW01108611 | 吡啶 | 99.5%,HyDry,with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 110-86-1 |
XW01108612 | 吡啶 | 99.5%,HyDry,with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 110-86-1 |
XW01108613 | 吡啶 | 99.5%,HyDry,with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 110-86-1 |
XW01239111 | 1,4-二氧六环 | 99.7%,HyDry,with molecular sieves, stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 123-91-1 |
XW01239112 | 1,4-二氧六环 | 99.7%,HyDry,with molecular sieves, stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯) | 500ml | 123-91-1 |
XW01239113 | 1,4-二氧六环 | 99.7%,HyDry,with molecular sieves, stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯) | 1L | 123-91-1 |
XW01428251 | 正庚烷 | 99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯) | 100ml | 142-82-5 |
XW00751611 | 甲基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 75-16-1 |
XW00751612 | 甲基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 75-16-1 |
XW00751613 | 甲基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 800ml | 75-16-1 |
XW00751616 | 甲基溴化镁(2~8℃) | 3.0 M solution in 2-Methyl-THF, HySeal(沃凯) | 100ml | 75-16-1 |
XW00751617 | 甲基溴化镁(2~8℃) | 3.0 M solution in 2-Methyl-THF, HySeal(沃凯) | 500ml | 75-16-1 |
XW00751618 | 甲基溴化镁(2~8℃) | 3.0 M solution in 2-Methyl-THF, HySeal(沃凯) | 800ml | 75-16-1 |
XW01005831 | 苯基溴化镁(2-8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 100-58-3 |
XW01005832 | 苯基溴化镁(2-8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 100-58-3 |
XW01005833 | 苯基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 800ml | 100-58-3 |
XW03521362 | 4-氟苯基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 352-13-6 |
XW03521363 | 4-氟苯基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 352-13-6 |
XW06765841 | 甲基氯化镁(2~8℃) | 3.0 M solution in THF, HySeal (沃凯) | 100ml | 676-58-4 |
XW06765842 | 甲基氯化镁(2~8℃) | 3.0 M solution in THF, HySeal(沃凯) | 500ml | 676-58-4 |
XW06772251 | 叔丁基氯化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 677-22-5 |
XW09203981 | 异丙基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 920-39-8 |
XW09203984 | 异丙基溴化镁(2~8℃) | 3.0 M in 2-Methyltetrahydrofuran, HySeal (沃凯) | 100ml | 920-39-8 |
XW09259061 | 乙基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 925-90-6 |
XW09259062 | 乙基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 925-90-6 |
XW09259064 | 乙基溴化镁(2~8℃) | 2.0 M solution in THF, HySeal(沃凯) | 100ml | 925-90-6 |
XW09315001 | 环己基溴化镁(2~8℃) | 1.0 M solution in THF,HySeal(沃凯) | 100ml | 931-50-0 |
XW09315002 | 环己基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 931-50-0 |
XW10685591 | 异丙基氯化镁(2-8℃) | 2.0 M solution in THF, HySeal (沃凯) | 500ml | 1068-55-9 |
XW10685592 | 异丙基氯化镁(2~8℃) | 2.0 M solution in THF, HySeal (沃凯) | 100ml | 1068-55-9 |
XW10685596 | 异丙基氯化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 1068-55-9 |
XW10685597 | 异丙基氯化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 1068-55-9 |
XW10685598 | 异丙基氯化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 800ml | 1068-55-9 |
XW18266711 | 乙烯溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 1826-67-1 |
XW18266712 | 乙烯溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 1826-67-1 |
XW18266713 | 乙烯溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 800ml | 1826-67-1 |
XW237198041 | 环丙基溴化镁(2~8℃) | 0.5 M solution in THF, HySeal(沃凯) | 100ml | 23719-80-4 |
XW237198044 | 环丙基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 23719-80-4 |
XW237198045 | 环丙基溴化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 23719-80-4 |
XW35369671 | 乙烯基氯化镁(2~8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 3536-96-7 |
XW35369674 | 乙烯基氯化镁(2~8℃) | 2.0 M solution in THF, HySeal(沃凯) | 100ml | 3536-96-7 |
XW43011481 | 乙炔基溴化镁(2~8℃) | 0.5 M solution in THF, HySeal(沃凯) | 100ml | 4301-14-8 |
XW43011482 | 乙炔基溴化镁(2~8℃) | 0.5 M solution in THF, HySeal(沃凯) | 500ml | 4301-14-8 |
XW43011483 | 乙炔基溴化镁(2~8℃) | 0.5 M solution in THF, HySeal(沃凯) | 800ml | 4301-14-8 |
XW69213421 | 苄基氯化镁(2-8℃) | 1.0 M solution in THF, HySeal(沃凯) | 100ml | 6921-34-2 |
XW7450388621 | 异丙基氯化镁-氯化锂(2~8℃) | 1.3 M solution in THF, HySeal(沃凯) | 100ml | 745038-86-2 |
XW7450388622 | 异丙基氯化镁-氯化锂(2~8℃) | 1.3 M solution in THF, HySeal(沃凯) | 500ml | 745038-86-2 |
XW41115405 | 二异丙基氨基锂(2~8℃) | 2.0 M solution in THF/n-heptane ethylbenzene, HySeal(沃凯) | 100ml | 4111-54-0 |
XW41115406 | 二异丙基氨基锂(2~8℃) | 2.0 M solution in THF/n-heptane ethylbenzene, HySeal (沃凯) | 500ml | 4111-54-0 |
XW41115407 | 二异丙基氨基锂(2~8℃) | 2.0 M solution in THF/n-heptane ethylbenzene, HySeal(沃凯) | 800ml | 4111-54-0 |
XW01244031 | 二甲胺(2-8℃) | 2M solution in THF, HySeal(沃凯) | 100ml | 124-40-3 |
XW01244032 | 二甲胺(2~8℃) | 2M solution in THF, HySeal(沃凯) | 500ml | 124-40-3 |
XW76644171 | 氨(2~8℃) | 7.0 M solution in MeOH, HySeal(沃凯) | 100ml | 7664-41-7 |
XW76644173 | 氨(2~8℃) | 0.4 M solution in 1,4-Dioxane, HySeal (沃凯) | 100ml | 7664-41-7 |
XW76644174 | 氨(2~8℃) | 0.4 M solution in 1,4-Dioxane, HySeal(沃凯) | 500ml | 7664-41-7 |
XW102943341 | 三溴化硼(2~8℃) | 17% in Methylene chloride,HySeal (沃凯) | 100ml | 10294-33-4 |
XW102943342 | 三溴化硼(2~8℃) | 17% in Methylene chloride,HySeal (沃凯) | 500ml | 10294-33-4 |
XW102943451 | 三氯化硼(2~8℃) | 1.0 M solution in Methylene chloride, HySeal(沃凯) | 100ml | 10294-34-5 |
XW102943452 | 三氯化硼(2~8℃) | 1.0 M solution in Methylene chloride, HySeal(沃凯) | 500ml | 10294-34-5 |
XW102943453 | 三氯化硼(2~8℃) | 1.0 M solution in Methylene chloride, HySeal(沃凯) | 800ml | 10294-34-5 |
XW102943454 | 三氯化硼(2~8℃) | 1.0 M solution in Hexanes, HySeal(沃凯) | 100ml | 10294-34-5 |
XW102943455 | 三氯化硼(2~8℃) | 1.0 M solution in Hexanes, HySeal(沃凯) | 500ml | 10294-34-5 |
XW76468571 | 氯化锌(2~8℃) | 1.0 M solution in THF, HySeal (沃凯) | 100ml | 7646-85-7 |
XW132928702 | 硼烷二甲基硫醚络合物(2~8℃) | 2.0 M solution in THF, HySeal(沃凯) | 500ml | 13292-87-0 |
XW140446563 | 硼烷四氢呋喃络合物(2-8°C) | 1.0 M solution in THF, HySeal(沃凯) | 500ml | 14044-65-6 |
XW140446564 | 硼烷四氢呋喃络合物(2-8°C) | 1.0 M solution in THF, HySeal(沃凯) | 1L | 14044-65-6 |
XW181071813 | 三甲基硅烷化重氮甲烷(2~8℃) | 2.0M in Hexane, HySeal(沃凯) | 100ml | 18107-18-1 |
更多缓冲颗粒品规及详情请询国药试剂销售部
