Model | DMBA210 | ||
Observation Tubes | Ergonomic 30 degree viewing angle | ||
55-75mm interpupillary distance | |||
Large field of view with 18mm or 20mm options | |||
Built-in Digital with 20/80 split and 3.0MP imaging sensor delivering high-resolution streaming images through a USB2.0 connection | |||
Eyepieces | N-WF 10x/18mm | ||
N-WF 10x/20mm | |||
N-WF 15x/13.3mm | |||
N-WF 12.5x/16mm | |||
Magnification | N.A. | W.D (mm) | |
EF-N Plan 4x | 0.1 | 6.3 | |
EF-N Plan 10x | 0.25 | 4.4 | |
EF-N Plan 20x | 0.4 | 4.66 | |
EF-N Plan 40x | 0.65 | 0.35 | |
EF-N Plan 60x | 0.85 | 0.13 | |
EF-N Plan 100x | 1.25 | 0.13 | |
EF-N Plan Phase 10x | 0.25 | 4.4 | |
EF-N Plan Phase 40x | 0.65 | 0.35 | |
Illumination Options | 6V/30W Halogen | ||
3W LED | |||
Mirror | |||
Condenser | Abbe 1.25NA with slot for accessories and condenser lock available | ||
Stage | Hard Coated Mechanical Stage with 76x30mm travel range | ||
Left or Right Stage drive available | |||
Other Options | Simple Phase Contrast 10x and 40x sliders for condenser | ||
Darkfield slider for condenser | |||
Simple Polarization with analyzer and polarizer |
