关于红外光谱两道题
测试版面
  • 用中文回答就行
    4. Both IR and Raman spectroscopies provide information on the vibrations of bonds, but in IR
    spectroscopy infrared radiation is input and in Raman the radiation input is often visible or UV.
    Explain why in terms of the underlying physical processes that occur.
    5. Although not always shown, Raman spectra could show Stoke’s, Rayleigh, and anti-Stoke’s peaks.
    Explain why the intensity and energy of these peaks are different from each other.
  • xmgulong
    第1楼2019/12/19
    4.红外和拉曼光谱都可以向我们提供分子振动的信息,但是在红外光谱中红外输入……(这个地方一定有误),拉曼光谱的输入射线一般是可见光或者紫外光。请解释为什么潜在的物理过程会发生(这句貌似也不通吧)。
    5.尽管没有完全显示出来,拉曼其实可以显示斯托克斯峰,瑞利散射峰和反斯托克斯射线峰。请解释为什么这些峰位置和强度会不一样。
