气相色谱条件的选择
测试版面
  • 最近我在一篇文献上看到如下的实验条件控制:
    Gas chromatography experiments (gc) were performed with a Shimadzu gc-16A instrument using a 2m column packed with silicon DC-200 or Carbowax 20m. The nitrogen was used as carrier gas and FID as detector. A temperature programming conditions (120–200℃) was operated for gc experiments.
    但是在文献中我发现其要测定的物质的沸点一般都在200-300℃之间,将温度设在120-200℃间是如何检测出来这些物质的,是不是与气相色谱柱的选择有关,求高人指点,不胜感激。
  • kite503
    第1楼2020/03/25
    在柱子承受不了的情况下为了降低样品进入色谱柱的量可以分流进样,别的就没什么了吧
