moonboygir
第1楼2020/04/14
我今天看了ISO GUIDE 98-3—2008(GUM:1995).在109页下方的注释写到:When the GUM was first published, there was an editorial rule in effect which prohibited the use of an Annex I. That is why the annexes go from Annex H directly to Annex J.
显然这是有意为之,我之前好像在某个标准的编写规范里也看到类似的要求,记不清了,不过这本2008已经回答了你的问题。
