flyheart
第1楼2007/03/04
E114 Standard Practice for Ultrasonic Pulse-Echo Straight-Beam Examination by the Contact Method
flyheart
第2楼2007/03/04
E125 Standard Reference Photographs for Magnetic Particle Indications on Ferrous Castings
flyheart
第3楼2007/03/04
E127 Standard Practice for Fabricating and Checking Aluminum Alloy Ultrasonic Standard Reference Blocks
flyheart
第4楼2007/03/04
E155 Standard Reference Radiographs for Inspection of Aluminum and Magnesium Castings
flyheart
第5楼2007/03/04
E164 Standard Practice for Ultrasonic Contact Examination of Weldments
flyheart
第6楼2007/03/04
E165 Standard Test Method for Liquid Penetrant Examination
flyheart
第7楼2007/03/06
E186 E186-98e1 Standard Reference Radiographs for Heavy-Walled (2 to 41/2-in. [51 to 114-mm]) Steel Castings
E186-98e1 Standard Reference Radiographs for Heavy-Walled 2 to 41/2-in. 51 to 114-mm Steel Castings
flyheart
第8楼2007/03/06
E192-95(Reapproved 1999) Standard Reference Radiographs for Investment Steel Castings of Aerospace Applications
E192-95 Standard Reference Radiographs for Investment Steel Castings of Aerospace Applications
flyheart
第9楼2007/03/06
E213-98 Standard Practice for Ultrasonic Examination of Metal Pipe and Tubing
flyheart
第10楼2007/03/06
E214-68(Reapproved 1996) Standard Practice for Immersed Ultrasonic Examination by the Reflection Method Using Pulsed Longitudinal Waves
E214-68 Standard Practice for Immersed Ultrasonic Examination by the Reflection Method Using Pulsed Longitudinal Waves
