xyz0402
第2楼2020/11/23
所以,Jade里卡片的备注:
NOTE: Chemical analysis (wt.%): CaO 41.69, Fe2 O3 56.50, MgO 1.19, MnO 0.90: Ca2.01 ( Fe1.91 +3 Mg0.08 Mn0.03 ) O5.00. Cell parameters generated by least squares refinement. Specimen from burnt lumps of petrified wood, Chelyabinsk basin, USSR. Fluoresces in ultraviolet light. To replace 00-003-0804. Brownmillerite is the Al analogue. Reference reports: a=5.420(3), b=14.752(3), c=5.594(3). See ICSD 14296 (PDF 01-071-2108).
这里的See ICSD 14296 (PDF 01-071-2108).只是说和ICSD的卡片有关联吗?
