外文文献求助
文献检索-互助
  • 悬赏金额:10积分状态:未解决
  • 求助外文文献一篇
    作者】 Bleishmidt, NV; Dreval, VE; Borodina, OE; Golova, LK; Kulichikhin, VG
  • 【期刊名】 VYSOKOMOLEKULYARNYE SOEDINENIYA SERIYA A and SERIYA B(1997年影响因子:0.256)
  • 【学科编号】 070305 ( 理学 -> 化学 -> 高分子化学与物理 )
  • 【摘要】Rheological characteristics of cellulose solutions in N-methylmorpholine-N-oxide were studied at 90-120 degrees C in a wide range of compositions. The viscosity of solutions with concentrations c < 0.....全部展开
  • 【摘要】Rheological characteristics of cellulose solutions in N-methylmorpholine-N-oxide were studied at 90-120 degrees C in a wide range of compositions. The viscosity of solutions with concentrations c < 0.18 wt. fract. obeys the laws characteristic of the solutions of flexible-chain polymers. It is shown that cellulose farms in solution a network of intermolecular contacts with a density much higher than that known in the solutions of flexible-chain polymers. This, together with increased rigidity of the cellulose backbone, leads to higher values of the modulus of elasticity. The cellulose solutions studied exhibited considerable broadening of the spectrum of relaxation times with increasing concentration. Cellulose solutions with c > 0.18 wt. fractions showed a considerable increase in the degree of structurization, which led to anomalous increase in the relaxation times, and the values of viscosity, activation energy for the viscous flow, and elastic moduli.收起
  • 【重要收录】CA
  • 【文献类型】期刊
  • hstudent
    第1楼2020/12/13
    发帖格式
    【序号】:
    【作者】:
    【题名】:
    【期刊】:
    【年、卷、期、起止页码】:
    【全文链接】:
  • 装作看见
    第2楼2020/12/13
    起码给个题目啊
  • 砂锅粥
    第3楼2020/12/14
    楼主求助的文献应该是:Rheology of concentrated N-methylmorpholine-N-oxide cellulose solutions
    貌似不好下载。找到2篇跟此文献有关系的,楼主参考一下看是否有用吧。
  • qq250083771
    第4楼2020/12/16
    不知道是不是这个
