mfxhuang 2007/04/10
this is. [img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=48434]paper[/url]
mitchie 2007/04/09
[quote]原文由 [B]shxie[/B] 发表: Title: Ruthenium-tin sol-gel catalysts: effect of the preparation and tin precursor influence Author(s): Hajek J, Kacer P, Murzin DY, Cerveny L Source: RESEARCH ON CHEMICAL INTERMEDIATES 28 (6): 561-573 2002 Document Type: Review Language: English email:temedx@gmail.com 多谢![/quote] J. Hájek, P. Kaer, D. Yu. Murzin and L. ervený Abstract The influence of the synthesis route and the chemical nature of tin precursors on the catalytic properties of supported sol-gel Ru-Sn/SiO2 catalysts were studied. It was demonstrated that introduction of tin afforded better selectivities than a monometallic sol-gel catalyst in the liquid-phase hydrogenation of cinnamaldehyde; however, the chemical nature of the tin precursor did not influence the catalyst performance. Sol-gel catalyst properties depended significantly upon the preparation method used and on the activation temperature. The selectivity to unsaturated alcohol increased with conversion, which is indicative of the in-situ creation of active sites selective in the carbonyl bond hydrogenation.
mitchie
第1楼2007/04/09
