leiws
第9楼2023/06/19
r_exp 2.507891312 r_exp_dash 9.339147199 r_wp 4.026124512 r_wp_dash 14.99290232 r_p 3.054802282 r_p_dash 20.50783714 weighted_Durbin_Watson 0.9054299524 gof 1.605382376
range 1
weight_percent_amorphous ~ 0
original_weight_percent_amorphous ~ 0
bkg @ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
start_X 15
Zero_Error(@, 0.01791510794)
Specimen_Displacement(~@, -0.03238706934)
LP_Factor( 0)
Rp 217.5
Rs 217.5
Slit_Width( 0.1)
Divergence( 1)
Tube_Tails(, 0.04,, -1,, 1,, 0.005)
axial_conv
filament_length 12
sample_length 15
receiving_slit_length 12
primary_soller_angle 4
secondary_soller_angle 4
axial_n_beta 20
axial_del 0.0053
lam
ymin_on_ymax 0.0001
la 0.0159 lo 1.534753 lh 3.6854
la 0.5791 lo 1.540596 lh 0.437
la 0.0762 lo 1.541058 lh 0.6
la 0.2417 lo 1.54441 lh 0.52
la 0.0871 lo 1.544721 lh 0.62
xy_yobs
xy_color 16711680
line_width 1
pt_size 0
xy_ycalc
xy_color 255
line_width 1
pt_size 0
xy_ydiff
xy_color 8421504
line_width 1
pt_size 0
str
CS_L(@, 9997.555352)
Strain_L(@, 0.1085352481)
xy_pks
xy_color 16711680
PVII_Peak_Type(@, 0,@, 0,@, 0,@, 0,@, 0,@, 0)
r_bragg 1.893479916
scale @ 0.0008019200592
phase_name Structure
MVW( 790.4187425, 188.8817743, 100)
space_group I4/mmm
Phase_LAC_1_on_cm( 1606.257873)
Phase_Density_g_on_cm3( 6.948908128)
Tetragonal(@ 4.15159431,@ 10.95873027)
site Ce1 num_posns 2 x 0 y 0 z 0 occ Ce 1 beq 0.02207633107
site Mn1 num_posns 4 x 0 y 0.5 z 0.25 occ Mn 1 beq 0.3991125806
site Ge1 num_posns 4 x 0 y 0 z 0.3829399752 occ Ge 1 beq 0.01371630466
ble 1
clp 1
cif_str 1
fcf 1
PO_Spherical_Harmonics(sh_647feaf7_41, 8 load sh_Cij_prm { y00 !sh_647feaf7_41_c00 1 y20 sh_647feaf7_41_c20 0.07922159195 y40 sh_647feaf7_41_c40 -0.003322804575 y44p sh_647feaf7_41_c44p 0.0001684570494 y60 sh_647feaf7_41_c60 -0.007656146011 y64p sh_647feaf7_41_c64p -0.05395442802 y80 sh_647feaf7_41_c80 -0.1126877503 y84p sh_647feaf7_41_c84p -0.1319292634 y88p sh_647feaf7_41_c88p -0.1032573395 } )
PO_Two_Directions(~@, 1,, ,~@, 1,, ,~@, 0.5)
fit_zoomed 1
科研SkyLine
第10楼2023/06/19
按照您的修改了一下,发现beq还是会出现负值,请教一下是咋回事呢,谢谢您
