一种以桃子风味为主调的电子烟油成分分析
电子烟油又名电子烟液,是配合电子烟使用的电子雾化液。通过电子烟雾化器加热,能够产生如香烟一样的雾气。电子烟油一般含甘油 PG等溶剂,比较粘稠,但是在进行GC/MS分析成分的时候只要充分评估样品状态,适当进行样品前处理,也是能够将电子烟油重点化学成分分析出来的。No | RT(min) | Name | ppm | CAS |
1 | 3.7201 | Dimethyl sulfide | 0.0283 | 000075-18-3 |
2 | 3.9523 | Ethyl acetate | 0.0095 | 000141-78-6 |
3 | 4.053 | Ethyl alcohol | 2.0670 | 000064-17-5 |
4 | 4.5536 | Ethyl butyrate | 0.3028 | 000105-54-4 |
5 | 4.6708 | Ethyl-2-methylbutyrate | 0.0197 | 007452-79-1 |
6 | 4.8281 | Butyl acetate | 0.0171 | 000123-86-4 |
7 | 5.2409 | Isoamyl acetate | 0.1522 | 000123-92-2 |
8 | 5.373 | Manzanate | 0.0021 | 039255-32-8 |
9 | 5.6639 | Myrcene | 0.0012 | 000123-35-3 |
10 | 5.7949 | Ethyl (E)-crotonate | 0.0123 | 000623-70-1 |
11 | 6.138 | Isopentyl formate | 0.0009 | 000110-45-2 |
12 | 6.2717 | Limonene | 0.0524 | 000138-86-3 |
13 | 6.4231 | 1,8-Cineole | 0.0016 | 000470-82-6 |
14 | 6.6093 | Ethyl caproate | 0.0068 | 000123-66-0 |
15 | 6.9235 | (E)-beta-Ocimene | 0.0027 | 003779-61-1 |
16 | 7.1367 | Butyl isovalerate | 0.0111 | 000109-19-3 |
17 | 7.2642 | Hexyl acetate | 0.0422 | 000142-92-7 |
18 | 7.363 | iso-Amyl 2-methylbutyrate | 0.0018 | 027625-35-0 |
19 | 7.6723 | iso-Amyl isovalerate | 0.0054 | 000659-70-1 |
20 | 8.1148 | Leaf acetate | 0.0355 | 003681-71-8 |
21 | 8.4477 | Ethyl heptanoate | 0.0044 | 000106-30-9 |
22 | 8.843 | Hexyl alcohol | 0.0015 | 000111-27-3 |
23 | 9.0656 | cis-Rose oxide | 0.0116 | 000876-17-5 |
24 | 9.2879 | Allyl hexanoate | 0.0129 | 000123-68-2 |
25 | 9.4003 | Rose oxide | 0.0010 | 016409-43-1 |
26 | 9.5881 | cis-3-Hexenol | 0.0759 | 000928-96-1 |
27 | 10.908 | Ethyl caprylate | 0.0037 | 000106-32-1 |
28 | 11.2173 | trans-2-Hexenal PG acetal | 0.0017 | 094089-21-1 |
29 | 11.5179 | Acetic acid | 0.0432 | 000064-19-7 |
30 | 11.6664 | Ethyl acetoacetate | 0.0117 | 000141-97-9 |
31 | 12.4126 | cis-3-Hexenyl isovalerate | 0.0273 | 035154-45-1 |
32 | 13.868 | Ethyl nonanoate | 0.0023 | 000123-29-5 |
33 | 14.1632 | Linalool | 0.0884 | 000078-70-6 |
34 | 14.538 | 1-Octanol | 0.0017 | 000111-87-5 |
35 | 14.799 | Menthyl acetate | 0.0031 | 000089-48-5 |
36 | 15.2137 | propylene glycol acetate | 0.0078 | 001331-12-0 |
37 | 16.7843 | Propylene Glycol | 35.7686 | 000057-55-6 |
38 | 17.128 | Unknown | 0.0247 | - |
39 | 18.6281 | Ethyl benzoate | 0.0028 | 000093-89-0 |
40 | 19.4039 | Styralyl acetate | 0.0281 | 000093-92-5 |
41 | 20.4455 | Benzyl acetate | 0.0365 | 000140-11-4 |
42 | 22.4728 | Allyl cyclohexyl propionate | 0.0074 | 002705-87-5 |
43 | 22.6499 | Nerol | 0.0040 | 000106-25-2 |
44 | 23.2409 | (Z)-beta-Damascone | 0.0075 | 023726-92-3 |
45 | 23.34 | Phenethyl acetate | 0.0053 | 000103-45-7 |
46 | 23.9731 | 2-Propanol, 1,1'-oxybis- | 0.0373 | 000110-98-5 |
47 | 24.2423 | Benzaldehyde propylene glycol acetal | 0.0199 | 002568-25-4 |
48 | 24.9976 | N,2,3-Trimethyl-2-isopropylbutamide | 1.7900 | 051115-67-4 |
49 | 25.3011 | Nicotine | 2.2232 | 000054-11-5 |
50 | 27.0784 | gamma-Octalactone | 0.0151 | 000104-50-7 |
51 | 28.0348 | Nicotine | 0.0117 | 000054-11-5 |
52 | 28.7849 | Maltol | 0.0921 | 000118-71-8 |
53 | 29.5325 | Diphenylether | 0.0191 | 000101-84-8 |
54 | 30.0345 | Ethyl maltol | 0.3770 | 004940-11-8 |
55 | 30.3996 | Furaneol | 0.6294 | 003658-77-3 |
56 | 30.598 | gamma-Nonalactone | 0.0361 | 000104-61-0 |
57 | 30.9398 | Octanoic acid | 0.0668 | 000124-07-2 |
58 | 31.7145 | Triacetin | 3.7091 | 000102-76-1 |
59 | 32.3598 | Methyl cinnamate | 0.0234 | 000103-26-4 |
60 | 33.6455 | Ethyl cinnamate | 0.1474 | 000103-36-6 |
61 | 34.0753 | gamma-Decalactone | 0.1034 | 000706-14-9 |
62 | 34.1476 | Cinnamyl acetate | 0.0240 | 000103-54-8 |
63 | 34.494 | Eugenol | 0.0030 | 000097-53-0 |
64 | 34.866 | Thymol | 0.0008 | 000089-83-8 |
65 | 35.7186 | Allyl phenoxyacetate | 0.0293 | 007493-74-5 |
66 | 36.181 | Allyl 2-Furoate | 0.0016 | 004208-49-5 |
67 | 36.29 | delta-Decalactone ethanol | 0.0012 | 000000-00-0 |
68 | 36.357 | Unknown | 0.0147 | - |
69 | 37.224 | Glycerol 1,2-diacetate | 0.0278 | 000102-62-5 |
70 | 37.4443 | 2(3H)-Furanone, 5-heptyldihydro | 0.1541 | 000104-67-6 |
71 | 37.966 | Methyl dihydrojasmonate | 0.0003 | 024851-98-7 |
72 | 39.2876 | Glycerin | 49.9181 | 000056-81-5 |
73 | 42.0645 | Benzoic acid | 1.5684 | 000065-85-0 |
