EU RoHS | Not Compliant |
Part Status | Obsolete |
Automotive | No |
PPAP | No |
Family Name | MAX® |
Program Memory Type | EPROM |
Number of Logic Blocks/Elements | 12 |
Number of Global Clocks | 1 |
Number of Macro Cells | 192 |
Process Technology | 0.8um |
Product Terms | 32 |
Device System Gates | 3750 |
Data Gate | No |
Maximum Number of User I/Os | 64 |
In-System Programmability | No |
Number of Inter Dielectric Layers | 2 |
Programmability | Yes |
Reprogrammability Support | No |
Maximum Internal Frequency (MHz) | 62.5 |
Maximum Clock to Output Delay (ns) | 14 |
Maximum Propagation Delay Time (ns) | 25 |
Speed Grade | 25 |
Individual Output Enable Control | No |
Minimum Operating Supply Voltage (V) | 4.75 |
Maximum Operating Supply Voltage (V) | 5.25 |
Typical Operating Supply Voltage (V) | 5 |
Maximum Operating Current (mA) | 380 |
Minimum Operating Temperature (°C) | 0 |
Maximum Operating Temperature (°C) | 70 |
Supplier Temperature Grade | Commercial |
Tradename | MAX |
Mounting | Surface Mount |
Package Width | 29.41(Max) |
Package Length | 29.41(Max) |
PCB changed | 84 |
Standard Package Name | LCC |
Supplier Package | Windowed LCC |
Pin Count | 84 |
