山路十八弯
第4楼2024/04/13
AATCC网站:
Standard Conditions
The manufacturers report that the following machines meet the parameters listed in the current versions of AATCC TM88B, TM88C, TM124, TM130, TM135, TM143, TM150, TM179, and TM207. These parameters are also listed in AATCC LP1, Home Laundering: Machine Washing, Table I. AATCC does not verify the parameters of washing machines or dryers.
– SDL Atlas Vortex M6
– Refond LaboWash RF6088W
– Labtex LBT-M6
– Introtech KMS-M6
Alternate Conditions
The manufacturers report that the following machines meet the parameters listed in the noted tables of AATCC LP1, Home Laundering: Machine Washing.
– Introtech KMS-M6(Tables I, IIC, IID, IIIA, IIIB)
– Labtex LBT-M6 (Tables I, IIC, IID, IIIA, IIIB)
– Labtex LBT-M6T (Tables IIA 1.8-kg load only, IIB 1.8-kg load only)
– Refond LaboWash RF6088W(Tables I, IIC, IID, IIIA, IIIB)
– SDL Atlas Vortex M6 (Tables I, IIC, IID, IIIA, IIIB)
– Whirlpool 3LWTW4840YW (Table IIC 3.6-kg load only)*
– Whirlpool 3LWTW4815FW (Table IIIB 3.6-kg load only)*
– Whirlpool 4KWTW4815FW (Table IIIB 3.6-kg load only)*
– Whirlpool WTW5000DW (Table IIIC 3.6-kg load only, revised Delicate water level)*
*On October 15, 2018, Whirlpool issued the following statement: “Due to the complexity of using a residential washer designed to calibrate the water levels based on load size and fabric types, we do not feel that our Whirlpool Residential Washers & Dryers will meet the needs of a standardized lab test unit in the future. Once the listed units are phased out, we will no longer pursue offering AATCC test machines.”
