鲸蜡基H exapeptide-8 通常被称为“罐装保妥适”,是一种肽化合物,用于减少由重复的面部表情引起的细纹,例如鱼尾纹、眉间纹或鼻唇纹。 Acetyl H exapeptide-8 促进皮肤自然产生1 型胶原蛋白,这是一种重要的蛋白质,可形成大的嗜酸性纤维以重建肌肉,减少细纹和皱纹。这种成分会阻断从神经到肌肉的信号;这些肌肉不再收缩,导致皱纹松弛和软化。日晒造成的皱纹和细纹不会对A cetyl H exapeptide-8 产生反应。
Acetyl H Exapeptide-8 promotes the skin's natural production of type 1 collagen, an important protein that forms large eosinophilic fibers to rebuild muscle and reduce fine lines and wrinkles. This blocks signals from nerves to muscles that no longer contract, causing wrinkles to relax and soften. Wrinkles and fine lines from the Sun do not respond to a cetyl H Exapeptide-8.
Studies have shown that Acetyl Hexapeptide-8 reduces the depth of wrinkles by up to 30 percent after 30 days of continuous use. Because of its structural similarity to botulinum toxin, acetyl hexapeptide 8 is considered an excellent non-invasive alternative to Botox. Restores the skin's natural water barrier and helps bind water to the skin, improving dryness. As type 1 collagen improves, it also helps improve skin elasticity.
三、它是如何工作的?
A cetyl H exapeptide-8具有与肉毒杆菌毒素相似的结构,通过控制神经递质的产生发挥作用。该肽的结构模仿 SNAP-25 蛋白的一个片段,可以放松面部肌肉,从而使皮肤外观变得光滑。
