Electrical Specifications (TA=25C) | |
Parameters | Specifications |
Frequency | 2-20 GHz |
Small Signal Gain | 30 minimum |
Gain Flatness | ±1.25 dB |
Noise Figure | 2.5 dB at mid band |
Input Return Loss | -10 dB |
Output Return Loss | -10 dB |
Pout | 16 dB minimum |
Operating DC Voltage | 12 Volts |
Operating DC Current | 100 mA |
Connectors | SMA Female |
DC Connector | Solder in Filter |
Absolute Maximum Rating | |
DC Voltage | 20 Volts |
RF Input Power | 5 dBm |
Operating Temperature | -40C to 85°℃ |
Storage Temperature | -55°C to 150°C |
