醉卧古隆中
第1楼2007/08/16
Toward Rapid and Well-Controlled Ambient Temperature RAFT Polymerization under UV-Vis Radiation: Effect of Radiation Wave Range
Lican Lu, Haijia Zhang, Nianfa Yang, and Yuanli Cai
Macromolecules; 2006; 39(11) pp 3770 - 3776Macromolecules39-3770
Supporting InformationSupporting Information
醉卧古隆中
第2楼2007/08/16
Functional Polymers from Novel Carboxyl-Terminated Trithiocarbonates as Highly Efficient RAFT Agents
Lai, J. T.; Filla, D.; Shea, R.
Macromolecules; (Communication to the Editor); 2002; 35(18); 6754-6756Macromolecules35-6754
醉卧古隆中
第3楼2007/08/16
Water-Soluble Polymers. 81. Direct Synthesis of Hydrophilic Styrenic-Based Homopolymers and Block Copolymers in Aqueous Solution via RAFT
Mitsukami, Y.; Donovan, M. S.; Lowe, A. B.; McCormick, C. L.
Macromolecules; (Article); 2001; 34(7); 2248-2256Macromolecules34-2248
