【求助】(已应助)求SPIE文章一篇
文献检索-互助
  • [题目] DC 5-MHz 100-A laser-diode driver
    [作者] Plamen D. Yankov and Dimitar Todorov
    Technical Univ. of Sofia (Bulgaria)
    [摘要]A new high power laser diode has been developed and tested. The possibilities for driving high power laser diode bars and stacks at high frequencies have been shown. The driver is with 0.05% noise and ripples at DC, and can be modulated with 15 ns rise/fall times at 100A, with maximum frequency for square wave modulation up to 5 MHz. The spikes for the optical output at switching on/off are not exceeding 5%. The limitation of the used scheme with the existing commercial components allows frequencies up to 25 MHz and currents to 400A to be reached. The driver opens new applications for high rate data transmission at long range, fast scanning designators, materials processing, etc. with laser diodes with more than 100W output power, which will be discussed.
    [全文链接] http://spiedl.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=PSISDG005618000001000090000001&idtype=cvips&gifs=yes
    [求助者email] zdyang8088@126.com
  • 该帖子已被管理者-设置为精华,下面是奖励记录:
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加2积分,加2声望
  • zdyang
    第2楼2007/09/24
    我开始是抱着试一试心理求助,想不到这么快就找到了。
    非常谢谢醉卧古隆中!我是新手只能这里再说一声谢谢了。
  • guichengkui
    第3楼2007/09/27
    厉害啊,我看都看的头晕
  • zdyang
    第4楼2007/09/27
    在工作中遇到激光器的电源问题,因此想了解一下而已,真的要用的话,还是买现成的保险。
