方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名:C60 in Water Nanocrystal Formation and Microbial Response 作者:J. D. FORTNER, D. Y. LYON, C. M. SAYES, A. M. BOYD, J. C. FALKNER, E. M. HOTZE, L. B. ALEMANY, Y. J. TAO, W. GUO, K. D. AUSMAN, V. L. COLVIN, AND J. B. HUGHES (Department of Civil and Environmental Engineering, Rice University, Houston, Texas 77005, Department of Chemistry, Rice University, Houston, Texas 77005, Department of Biochemistry and Cell Biology, Rice University, Houston, Texas 77005, Center for Biological and Environmental Nanotechnology, Rice University, Houston, Texas 77005, and School of Civil and Environmental Engineering, Georgia Institute of Technology, Atlanta, Georgia 30332) 摘要:Upon contact with water, under a variety of conditions, C60 spontaneously forms a stable aggregate with nanoscale dimensions (d=25-500 nm), termed here “nano-C60”. The color, hydrophobicity, and reactivity of individual C60 are substantially altered in this aggregate form. Herein, we provide conclusive lines of evidence demonstrating that in solution these aggregates are crystalline in order and remain as underivatized C60 throughout the formation/ stabilization process that can later be chemically reversed. Particle size can be affected by formation parameters such as rates and the pH of the water addition. Once formed, nano-C60 remains stable in solution at or below ionic strengths of 0.05 / for months. In addition to demonstrating aggregate formation and stability over a wide range of conditions, results suggest that prokaryotic exposure to nano-C60 at relatively low concentrations is inhibitory, indicated by lack of growth (≥0.4 ppm) and decreased aerobic respiration rates (4 ppm). This work demonstrates the fact that the environmental fate, distribution, and biological risk associated with this important class of engineered nanomaterials will require a model that addresses not only the properties of bulk C60 but also that of the aggregate form generated in aqueous media.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
