方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Adsorption and desorption behavior of Bovine Serum Albumin (BSA) on surface-modified magnetic nanoparticles covered with thermosensitive polymer (PNIPAM) was investigated as a function of temperature, pH, and ionic strength. Functionalization of surface-modified magnetic particles was performed by seed polymerization using N-isopropylacrylamide (PNIPAM) as the main monomer. Characterization of these particles was carried out using transmission electron micrography (TEM), and vibrating sample magnetometry (VSM). The adsorption results exhibited both pH and temperature sensitivity. The results showed that the temperature effect on adsorption/desorption behavior was mainly dependent on the properties of the particles’ surface. The effect of pH was also investigated and it was observed that a smaller amount of protein was adsorbed at higher pH because of the electrostatic repulsive force between protein molecules and latex particles. The maximum amount of protein was adsorbed near the isoelectric point of BSA. Desorption results showed that more protein was desorbed when adsorption was done at lower temperatures and desorption efficiency was found to be higher than 80%.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
