方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Surface topography is one of the most important factors influencing the attachment and spreading of cells. In the present study, layer-by-layer assembled titanium dioxide (TiO2) nanoparticle thin films were chosen for attachment, proliferation and spreading studies on mouse mesenchymal stem cells (MSC). Increasing surface roughness was observed with increasing number of layer-by-layer assembled TiO2 thin films. Four layer TiO2 thin film showed higher number of attached cells than a one layer thin film and control surfaces. MSCs experienced no cytotoxic effects after culture on the TiO2 coated substrates as observed from the cytotoxicity tests. Cell spreading, visualized with scanning electron microscopy, showed a faster rate of spreading on a rougher surface. Cells on a four-layer substrate, at 12 h showed complete spreading, where as most of the cells on a control surface and a one-layer surface, at 24 h, retained a rounded morphology. In conclusion, TiO2 nanoparticle thin films were successfully assembled in alternation with polyelectrolytes and in-vitro studies with MSC showed an increase in the attachment and faster spreading of cells on rougher surfaces.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
