方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The hypothesis tested in this paper is that quorum sensing influences the microbial surface electrokinetic properties. Escherichia coli MG1655 and MG1655 LuxS- mutant (lacking quorum-sensing gene for Autoinducer synthase AI-2) were used for this study. AI-2 production (or lack of) in both strains was analyzed using the Vibrio harveyi bioassay. The levels of extracellular AI-2 with and without glucose in the growth medium were consistent with previously published work. The surface electrokinetic properties were determined for each strain of E. coli MG1655 by measuring the electrophoretic mobility using a phase amplitude light-scattering (PALS) Zeta potential analyser. The findings show that the surface charge of the cells is dependent upon the stage in the growth phase as well as the ability to participate in quorum sensing. In addition, significant differences in the electrophoretic mobility were observed between both strains of E. coli. These findings suggest that quorum sensing plays a significant role in the surface chemistry of bacteria during their growth.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
