方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The transport of stabilized zerovalent iron nanoparticles (nZVI) has recently been the topic of extensive research due to its proven potential as an in situ remediation tool. However, these studies have ignored the effects of biofilms—complex aggregations of bacterial cells and excreted extracellular polymeric substances present in nearly all aquatic systems—on the transport of these particles. This study examines the effects of Pseudomonas aeruginosa (PAO1) biofilm, at a cell concentration similar to that reported for saturated aquifers, on the transport of commercially available, poly (acrylic acid) stabilized nZVI (pnZVI) in 14 cm long columns packed with saturated glass beads at salt concentrations of 1 and 25 mM NaCl. Compared to retention on uncoated columns, in the presence of biofilm the retention of pnZVI increased at higher ionic strength, while ionic strength played no role in retention of these nanoparticles in the absence of biofilm. The Tufenkji–Elimelech correlation equation predicts lower retention of pnZVI on biofilm coated columns compared to uncoated columns due to a lower Hamaker constant, and DLVO energy considerations predict the most favorable attachment to uncoated porous media at higher ionic strength. A steric (polymer-mediated) model that considers the combined influence of steric effects of polymers and DLVO interactions is shown to adequately describe particle retention in columns.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
