方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Amylose readily dissolves in hot water, unlike amylopectin which is largely insoluble. However, size distributions of amylose isolated in such a manner often show the presence of hyper-branched material consistent with amylopectin. The difference in solubility suggests that the hot-water-soluble (HWS) hyper-branched material might be structurally distinct from typical amylopectin. In the present paper, the structural properties of the two solubility fractions of hyper-branched material are explored in a set of traditional waxy rice varieties. The objective was to elucidate the nature of the HWS component, e.g. to see if it could be phytoglycogen, another water-soluble polysaccharide. We show that solubility is controlled by thermodynamic effects, rather than slow dissolution (kinetic effects). The average size, degree of branching and the debranched chain-length distributions indicate that the HWS fraction is structurally different from phytoglycogen. The debranched chain-length distributions of short chains and the degrees of branching in the HWS material are similar to those of the hot-water-insoluble (HWI) fractions but the chain-length distributions indicate that the HWI fractions carry longer chains than those in the HWS fractions. Light-scattering measurements show that the average size of whole molecules in the HWI component is significantly greater than in the HWS component. It is postulated that the structural differences limit solubility of the molecules in the HWI fraction, possibly due to co-crystallisation with adjacent molecules at more points than is possible for the shorter chains in HWS molecules.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
