方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Static light scattering of high amylopectin waxy maize starch gently dispersed in 90% dimethyl sulfoxide–water yielded a weight average molecular weight Mw and radius of gyration Rg of 560×106 g/mol and 342 nm, respectively. To obtain an independent hydrodynamic characterization of these solutions, we measured the sedimentation coefficient for the main component in an analytical ultracentrifuge. The value of s0, the infinite dilution sedimentation coefficient, was 199 S. The translational diffusion coefficient D0 in very dilute solutions was measured by dynamic light scattering at 90° and found to be 2.33×10-9 cm2/s. An effective hydrodynamic radius Rh was calculated from this diffusion constant using the Stokes–Einstein equation and found to be 348 nm. The structure-related parameter ρ=Rg/Rh was calculated to be 0.98. The weight average molecular weight calculated from the Svedberg equation using the values measured for s0 and D0 was 593×106 g/mol. This result is in reasonable agreement with the light scattering results. As light scattering results are subject to experimental errors due to the possibility of dust contamination, the presence of microgel or aggregates, and the questionable applicability of light scattering theory to interpret results for macromolecular sizes approaching the wave length of light used as a source for scattering, it is advisable to have corroborating hydrodynamic data when possible to further validate light scattering results in this very high molecular weight range.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
