方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The aggregation kinetics of silver nanoparticles (AgNPs) that were coated with two commonly use agents—citrate and polyvinylpyrrolidone (PVP)—were investigated. Time-resolved dynamic light (DLS) was employed to measure the aggregation kinetics of the AgNPs over a range of monovalen electrolyte concentrations. The aggregation behavior of citrate-coated AgNPs in NaCl was in excel with the predictions based on Derjaguin–Landau–Verwey–Overbeek (DLVO) theory, and the Ham of citrate-coated AgNPs in aqueous solutions was derived to be 3.7 × 10 J. Divalent electrolytes efficient in destabilizing the citrate-coated AgNPs, as indicated by the considerably lower critical c concentrations (2.1 mM CaCl and 2.7 mM MgCl vs. 47.6 mM NaCl). The PVP-coated AgNPs w significantly more stable than citrate-coated AgNPs in both NaCl and CaCl , which is likely due to repulsion imparted by the large, non-charged polymers. The addition of humic acid resulted in the the macromolecules on both citrate- and PVP-coated AgNPs. The adsorption of humic acid induce electrosteric repulsion that elevated the stability of both nanoparticles in suspensions containing Na concentrations of CaCl . Conversely, enhanced aggregation occurred for both nanoparticles at high concentrations due to interparticle bridging by humic acid clusters.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
