方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
ABSTRACT: Amphiphilic diblock copolymers were synthesized based on poly(2-ethyl-2-oxazoline) (PEtOz) as a hydrophilic block and aliphatic polyesters such as poly(L-lactide) (PLA) or poly(-caprolactone) (PCL) as a hydrophobic block. Their micellar characteristics in an aqueous phase were investigated by using dynamic light scattering and fluorescence techniques. The block copolymers formed micelles in the aqueous phase with critical micelle concentrations (cmcs) in the range of 1.0-8.1 mg/L. The cmc values become lower upon increasing the length of the hydrophobic block. The mean diameters of the micelles were in the range of 108-192 nm, with a narrow distribution. In general, the micelle size increased as the hydrophobic PLA or PCL block became larger. The partition equilibrium constants, Kv, of pyrene in the micellar solutions of the block copolymers were from 1.79 105 to 5.88 105. For each block copolymer system of PEtOz-PLA or PEtOz-PCL, the Kv value increased as the length of the hydrophobic block increased. The steady-state fluorescence anisotropy values (r) of 1,6-diphenyl-1,3,5-hexatriene (DPH) were 0.265-0.284 in PEtOz-PLA solution and 0.189-0.196 in PEtOz-PCL solution. The anisotropy values of PEtOz-PLAs were higher than those of PEtOz-PCLs. The anisotropy values were independent of the length of the hydrophobic block when the chemical structures of the hydrophobic blocks were identical. The micelles underwent hydrogen bonding at pH <3.5 with poly(acrylic acid), which produced polymer complex precipitates that could be reversibly dispersed as micelles at pH >3.8.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
