方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Effects of 360-kHz ultrasound on aqueous solutions of chitosan and starch were studied. This treatment is an efficient procedure for reduction of molecular weight of both polysaccharides. It has been demonstrated that at the applied ultrasound frequency degradation is caused both by OH radicals and mechanochemical effects. In Ar-saturated 2×10?2 mol dm?3 chitosan solutions, pH 3, at an ultrasound dose rate of 170 W kg?1, the average sonochemical chain scission yield in the sonication time range of 0–90 min is ca. 8×10?11 mol J?1. This yield has been shown to depend on polymer concentration, ultrasound power and gas used to saturate the solution. Scission is accompanied by side reactions leading to the formation of carbonyl groups. Ultrasound-induced chain scission of starch proceeds with lower yield, one of the reasons being probably the different chain conformation when compared with rod-like chitosan macromolecules.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
