方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
We developed a novel method to fabricate nanocomposite monodisperse SiO2 spheres (~100 nm) containing homogeneously dispersed Ag quantum dots (2~5 nm). The inclusion morphology is controlled through the timing of the photochemical reduction of silver ions during hydrolysis of tetraethoxysilane in a microemulsion. Depending on the timing, Ag quantum dots can be directed to different annuli within the SiO2 spheres, as well as onto the SiO2 sphere surfaces. The embedded Ag quantum dots show a plasmon resonance absorption band at 438 nm. These Ag@SiO2 particles have significant surface charge and readily self-assemble into crystalline colloidal array (CCA) photonic crystals which Bragg-diffract light in the visible region. The magnitude of the plasmon resonance absorption depends on the CCA Bragg diffraction condition. The negative dielectric constant of the silver nanoparticles may be decreasing the silica?silver nanodot composite refractive index below that of the water medium. We may be observing an analogue of the Borrmann effect previously observed in X-ray scattering, where the incident and diffracted electric field standing wave becomes localized in regions of small CCA crystal absorption.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
