方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Background Gene delivery vectors that restrict the expression of a therapeutic gene to a particular type of cells are critical to gene therapy in a complex structure, such as the central nervous system. We constructed a nonviral vector for targeted gene transfer to cells expressing nerve growth factor (NGF) receptor TrkA. Methods and results The vector was a synthetic chimeric peptide composed of a targeting moiety derived from NGF loop 4 and a DNA-binding moiety of 10 lysine residues. The peptide activated signal transduction pathways of the NGF receptor TrkA in PC12 cells and supported the survival of the cells after serum deprivation. After forming complexes with plasmid DNA, the peptide dose-dependently increased reporter gene expression in PC12 cells, which could be inhibited by excess NGF. The peptide-mediated gene expression was not affected in PC12 cells by co-incubation with a blocking antibody against the low-affinity NGF receptor p75 and was significantly enhanced in NIH3T3 cells stably transfected with TrkA cDNA, suggesting the involvement of the high-affinity NGF receptor TrkA without the participation of p75. Moreover, the peptide did not assist gene transfer in TrkA-poor, but TrkB- and/or TrkC-positive primary cerebellar granule neurons and primary cortical glial cells. Conclusions The chimeric peptide reported will be useful in gene delivery to and gene therapy of the nervous system and other tissues/organs with cells expressing TrkA.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
