方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A series of new aggregation-induced emission enhancement derivatives from bis(triphenylethylene) with strong blue-light-emitting properties and high thermal stability have been synthesized. Their maximum fluorescence emission wavelengths range between 464–468 nm, with fluorescence quantum yields of 0.58–0.88. Their glass transition temperatures range from 125 °C to 178 °C. The obtained experimental results demonstrate the different aggregation-induced emission enhancement phenomena caused by the effect of solvent and formation of both H- and J- aggregation states. An emitting device was fabricated using a bis(triphenylene) derivative in the emitting layer which exhibited a luminance efficiency of up to 2 cd/A with a maximum brightness of 548 cd/m2.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
