方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Unstable biopolymer solutions inevitably lead to mis-characterization of macromolecular properties and irreproducible results. Even under stable or quasi-stable conditions, persistent aggregates can hamper reliable characterization, especially using light scattering methods. Various pitfalls in characterizing biopolymers were worked through, including determination of solution stability zones, dissolution kinetics, estimation of fraction of aggregate populations, and the relationship between batch and fractionation methods. Chitosans, polyampholytic biopolymers with isoelectric point around pH = 6.0, with varying degrees of carboxymethylation were studied. Instability was determined vs. pH and ionic strength using a high throughput screening method, simultaneous multiple sample light scattering (SMSLS). With stable solution conditions determined, equilibrium batch and multi-detector GPC characterization of molecular weight, intrinsic viscosity, and polyelectrolyte properties was made. Finally, a first attempt at continuous online monitoring of the modification reaction itself was made and compared to FTIR analysis of carboxymethylation on discrete aliquots. Given the range of possible characterization problems, multiple approaches with independent instruments may be required for reliable natural product characterization. Online monitoring of modification reactions may lead to rapid advances in understanding and preparation of natural products.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
