方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Polymeric Suppression of Dopant-Enhanced Surfactant Supramicellar Assemblies 作者: Zifu Zhu and Wayne F. Reed 摘要:Certain hydrophobic dopants in surfactant solutions cause massive “supramicellar assemblies” (SAs) to form near the critical micelle concentration (CMC), characterized by a light-scattering peak (LSP). The SAs are large, dynamic, metastable nanostructures composed of surfactant/dopant. Here, a water-soluble polymer, poly(vinylpyrollidone) (PVP) suppresses SA formation in sodium dodecyl sulfate (SDS) solutions doped with dodecanol, but increases solution instability. Binding of SDS to PVP is stronger than micellization in the LSP regime, reflected in a decreased SA population and a dramatic reduction and inversion of Rayleigh scattering IR as [PVP] increases, since SAs are much more massive than PVP/SDS association structures. Above the LSP regime, SAs no longer exist and thus IR must re-establish its order, increasing with increasing [PVP]. This causes a cross-over in IR vs [SDS] with an “iso-scattering point,” where IR converges at a specific [SDS]. Weak LSP suppression is found using dodecyl tri-ethyl ammonium bromide (DTAB). Poly(ethylene oxide) (PEO)’s effect is small compared with PVP. 关键词:light-scattering peak;supramicellar assemblies;surfactant–polymer interaction
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
