Interfacial silica nanoparticles stabilize cocontinuous polymer blends
2015/03/12   下载量: 1
方案下载
应用领域
检测样本
检测项目
参考标准
We investigated the formation of cocontinuous structures in polymer blends. These polymeric bijels (bicontinuous interfacially jammed emulsion gels) were composed of polystyrene oligomer, polybutene and fluorescent hydrophobic silica nanoparticles. A micron-sized cocontinuous morphology was stabilized by a monolayer of silica nanoparticles at the interface. Real-time observation of coalescence dynamics in co-continuous polymer blends stabilized by interfacial particles was for the first time achieved via laser scanning confocal microscopy. We demonstrated that suppression of coalescence arises from coverage of interfaces by nanoparticles. Furthermore, by combining confocal microscopy with rheology, we correlated the rheological response of a cocontinuous structure with its morphology change. We found that the rheological behavior can be attributed to competition between interface shrinkage and particle network formation. In addition, we showed that a particle scaffold is maintained even after the remixing of two polymer phases above the spinodal point. Finally, we also discussed differences between the shear response of the particle-stabilized cocontinuous structure and normal colloidal gels: the former one is more fragile than the latter under shear.
方案下载
上一篇 NanoBrook产品应用-12-ZetaPALS
下一篇 The Structure-Function Relationship of PAMAM Dendrimers as Robust Oil Dispersants
文献贡献者
相关方案
当前位置: 美国布鲁克海文 方案 Interfacial silica nanoparticles stabilize cocontinuous polymer blends
