方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The European Standard method, EN-14105, is used to determine the free glycerol and residual mono-, di- and triglyceride contents in fatty acid methyl esters (FAME) typically intended for addition to mineral oils. Total glycerol content is calculated from the results obtained. The method is suitable for FAME from rapeseed, sunflower and soybean oils, but is not suitable for FAME produced from or containing coconut and palmkernel oils due of the problem of peak overlapping. This method and ASTM D6584 are two of the most commonly used standardized analytical methods used for the analysis of biodiesel.
4D-脂质组学高通量工作流程
PASEF应用于COVID-19的高通量定量大规模血浆蛋白质组学研究
布鲁克neofleX™ MALDI-TOF/TOF 空间成像质谱仪
布鲁克 timsTOF Ultra 2 捕集离子淌度质谱系统
布鲁克 timsTOF HT 捕集离子淌度质谱仪
PepSep™ 色谱柱
布鲁克scimaX™磁共振质谱仪
布鲁克 timsTOF fleX with MALDI-2
布鲁克timsTOF Pro 2 捕集离子淌度质谱
布鲁克 timsTOF fleX 组学和成像质谱系统
布鲁克ultrafleXtreme MALDI TOF/TOF质谱
布鲁克 timsTOF MALDI PharmaPulse
autoflex maX MALDI-TOF(TOF) 质谱
布鲁克solariX磁共振质谱仪
布鲁克 maXis II 飞行时间串联质谱
布鲁克 compact 高分辨飞行时间质谱
布鲁克impact II四极杆飞行时间质谱仪
