NA-EDS for TEM-半导体
2018/01/08   下载量: 15
方案下载
应用领域 半导体
检测样本 其他
检测项目
参考标准
Development and testing of semiconductor devices requires extensive knowledge of local structure and elemental composition. With feature sizes of <5 nm, it is often necessary to perform imaging and EDS analysis in a S / TEM. Once in the TEM, there are still many difficulties to be overcome to acquire accurate elemental maps. Elemental analysis of semiconductors is typically difficult due to strong overlaps of X-ray lines between commonly used elements and low concentrations of dopants. Not only are concentrations of dopants small but their X-ray lines often overlap with other materials used in semiconductor processing. This brief shows how AZtecTEM solves these overlaps to achieve an accurate elemental analysis. TEM Semiconductor Mapping in the TEM Solving peak overlaps in real-time Application Brief
方案下载
配置单
方案详情
Application Brief
上一篇 一文了解 EDS 能谱技术发展历程
下一篇 NA-EDS/EBSD-AZtec-高熵合金
文献贡献者
相关方案
当前位置: 牛津仪器 方案 NA-EDS for TEM-半导体
