材料成分和结构
2019/07/31   下载量: 0
方案下载
应用领域 钢铁/金属
检测样本 其他
检测项目 理化分析>金相分析
参考标准
Metals alloys and ceramics have a place in almost all of global manufacturing. Whether it is the turbine blades in a jet engine, the ceramic brake pads on a sports car or the steel cables for a suspension bridge, understanding the composition and structure of these materials is critical in understanding their properties.
方案下载
配置单
方案详情
Metals alloys and ceramics have a place in almost all of global manufacturing. Whether it is the turbine blades in a jet engine, the ceramic brake pads on a sports car or the steel cables for a suspension bridge, understanding the composition and structure of these materials is critical in understanding their properties. Using electron microscopy it is possible to characterise both these properties. Understanding the distribution and composition of nanoscale precipitates in Ni-based superalloys is crucial to understanding their performance under extreme temperatures. Using energy dispersive x-ray spectrometry (EDS) in the transmission electron microscope (TEM) allows -resolution analysis of these materials to determine the chemistry of these precipitates. Our X-MaxN 100TLE EDS is the perfect solution for this; the sensitivity allows analysis to be performed quickly and accurately whilst remaining sensitive to trace elements that may arise from contamination during the manufacturing process.
上一篇 一文了解 EDS 能谱技术发展历程
下一篇 工艺矿物学与化学分析
文献贡献者
相关方案
当前位置: 牛津仪器 方案 材料成分和结构
