Contamination in Li ion battery raw materials
2020/06/15   下载量: 1
方案下载
应用领域 能源/新能源
检测样本 锂电池
检测项目
参考标准
Summary Impurities and contaminants in the material used in the production of Li-ion batteries can have catastrophic impacts on the finished products. As such, monitoring of the quality and cleanliness of materials throughout the production process is essential if contaminants are to be found and their sources controlled. This monitoring must start with the raw materials produced at the mine and continue through to the final battery grade powders. This application note demonstrates a scanning electron microscopy (SEM) based solution for automatic detection and identification of impurities in battery raw material powders. By taking samples at different steps of the production process it is possible to identify where contaminants are introduced; thereby allowing sources to be identified and solutions developed.
方案下载
配置单
方案详情
Summary
上一篇 一文了解 EDS 能谱技术发展历程
下一篇 Characterising Complex Rock Samples using Symmetry
文献贡献者
相关方案
当前位置: 牛津仪器 方案 Contamination in Li ion battery raw materials
