方案下载应用领域 | 食品/农产品 |
检测样本 | 其他方便食品 |
检测项目 | 理化分析>水分 |
参考标准 | - |
The degree of substitution for sulfobutyl ether b-cyclodextrin (SBE-b-CD) has historically been characterized by nuclear magnetic resonance spectroscopy, but this approach provides gross values for the degree of substitution. The capillary electrophoresis method described here resolves the mixture of positional and regional isomers based on the degree of sulfo butyl ether substitution. Indirect UV detection has been used, where the detection of cyclodextrin is accomplished by a decrease in background absorbance of the background electrolyte buffer benzoic acid. Ten peaks of SBE-b-CD were well resolved with an optimum pH of 8.0 using an Agilent 50 μm id, 56 cm length bare fused silica capillary. The system suitability requirements were passed as per United States Pharmacopeia (USP), and acceptence criteria for averge degree of substitution 6.2 to 6.9 were met.
使用 Agilent 8697 顶空进样器和 8850 GC-FID 系统进行制药行业的残留溶剂分析
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
