方案下载应用领域 | 制药/生物制药 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
LC-MS/MS is widely used in every stage of drug development, from discovery and characterization through manufacturing and quality control of the final pharmaceutical product. Due to its excellent selectivity for complex molecules, LC-MS/MS is an effective tool for both non-target qualitative analysis and quantitative analysis of targeted compounds. However, the sensitivity of LC-MS/MS varies significantly depending on the molecular structure of each compound, and can be affected by other coexisting substances in the sample. This limitation means that LC-MS/MS is often unable to provide accurate quantitative analysis without a compound-specific calibration standard. Inductively Coupled Plasma Mass Spectrometry (ICP-MS) is a fast multi-element technique capable of accurate elemental quantification at trace and ultra-trace levels. While more widely adopted in inorganic, “metals” laboratories, ICP-MS is also used in the field of pharmaceutical analysis when a heteroatom-containing drug is the focus of interest [1, 2]. ICP-MS employs a high temperature plasma ion source that decomposes the sample to the atomic level. The high temperature
LC-MS/MS is widely used in every stage of drug development, from discovery and characterization through manufacturing and quality control of the final pharmaceutical product. Due to its excellent selectivity for complex molecules, LC-MS/MS is an effective tool for both non-target qualitative analysis and quantitative analysis of targeted compounds. However, the sensitivity of LC-MS/MS varies significantly depending on the molecular structure of each compound, and can be affected by other coexisting substances in the sample. This limitation means that LC-MS/MS is often unable to provide accurate quantitative analysis without a compound-specific calibration standard. Inductively Coupled Plasma Mass Spectrometry (ICP-MS) is a fast multi-element technique capable of accurate elemental quantification at trace and ultra-trace levels. While more widely adopted in inorganic, “metals” laboratories, ICP-MS is also used in the field of pharmaceutical analysis when a heteroatom-containing drug is the focus of interest . ICP-MS employs a high temperature plasma ion source that decomposes the sample to the atomic level. The high temperature
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
