方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
This workflow is suitable for batch-to-batch sample analysis for detecting and quantifying known potential genotoxic compounds
This study demonstrates a routine screening of drugs to identify and quantify potential genotoxic compounds. In this Application Note, we used an Agilent 6545 Q-TOF LC/MS system to acquire accurate mass data of samples containing chlorhexidine as the drug substance. Agilent MassHunter Mass Profi ler software was used to mine the data and compare different samples to generate a differential list of compounds. An accurate mass database search against the differential list identifi ed 4-chloroaniline, a potential genotoxic compound. All Ions MS/MS acquisition mode was used to confi rm 4-chloroaniline by MS/MS library matching, and quantify it using external standards. This workflow is suitable for batch-to-batch sample analysis for detecting and quantifying known potential genotoxic compounds
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
