方案下载应用领域 | 食品/农产品 |
检测样本 | 其他粮食加工品 |
检测项目 | 营养成分>产品品质等级 |
参考标准 | - |
Rice fermented with the mold Monascus purpureus, also known as the red yeast rice (RYR) used in traditional Chinese medicine, contains pharmacologically important monacolins. The prescription statin, lovastatin, is identical to monacolin K, and there is a suspicion of spiking RYR products with lovastatin. Profiling authentic and raw RYR samples has the potential to distinguish the spiked from natural product. Monascus purpureus is also known to produce the mycotoxin citrinin. Sudan red G, considered possibly genotoxic or carcinogenic by the European Food Safety Authority (EFSA), is a RYR adulterant. Pigments produced by Monascus spp. Are used as coloring agents. To address regulatory requirements, and assess product and raw material quality, origin, and safety, a robust method for characterizing and quantitating monacolins, pigments, and contaminants such as citrinin is needed. This application note presents a method that uses the Agilent Accurate-Mass Q-TOF LC/MS system and Agilent MassHunter Workstation software with principal component analysis (PCA) to characterize three authentic (AU) RYR samples, 31 RYR raw materials (CR), and 14 dietary supplements (DS). Quantitation was performed using UHPLC DAD. The method uncovered notable variation among RYR samples and raw materials. High mass accuracy Q-TOF LC/MS data enabled determination of compound identities, including identities of isobaric compounds. PCA showed that monacolin and pigment type could be used to classify RYR samples to determine the authenticity and quality of other RYR samples.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
