方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
Polyvinyl butyral (PVB) is a resin prepared from polyvinyl alcohol by reaction with butyraldehyde. PVB is an important material that has a wide range of uses in applications that require strong binding, optical clarity, excellent surface adhesion, toughness and flexibility. The most well-known application of PVB is in laminated safety glass, for example, in the windscreens of vehicles. In such products, PVB is used as an interface layer between two sheets of toughened glass. The interface layer absorbs the energy of impacts, binding broken shards of glass together and distributing the force of the impact over a wide area. The use of laminated glass has greatly reduced injuries resulting from automobile accidents. As it is the viscoelastic properties of PVB that contribute to its performance in glass laminates, the molecular weight distribution of the material must be closely monitored to ensure optimum performance. Gel permeation chromatography (GPC) with triple detection, employing a light scattering detector and viscometer, may be used to determine accurate molecular weights for polymers such as PVB. Three PVB materials were analyzed using these techniques, one of which did not perform as expected in application testing.
用于原辅料鉴定的 Agilent Cary 630 FTIR 光谱仪
分析洗手液中的醇类浓度
使用 Agilent Cary 630 ATR-FTIR 光谱仪测定婴儿米粉中的蔗糖浓度
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
